1 - 8 of 8 Posts
I purchased some S Flares for my 50" and they came with a bag of plastic rivots. The problem is none of them are long enough. Do they make longer rivots or do I have to use nuts and bolts? If they make longer rivots, where cam I get them?
Auto parts store like NAPA has some in different lengths. Just take one of the originals with you and they can size it. E-bay usually has a lot of them to but not sure if they are longer.
Should of had some bolts with it too, if I remember right most of the flair is bolted, with the Torx headed
Discussion Starter · #4 ·
Yep, just checked a parts catalog and it looks like they used Bolts and Retainer Clips.
When I got my S flaresI didn't see the bolts in the box. I started using some SS 1/4 20 bolts I had, until I went to throw the box away and found the bolts that came with the flares.
I switched the SS out with the hardware that came with them, it looked better with the black screws.
1 - 8 of 8 Posts
