UTV INC Polaris Sealed Wheel Bearing Greasing Tool! No need to remove the entire assembly to service them! Simply remove the axle nut & hub, slide the greasing tool over the axle and pump the bearings with grease! CNC made from billet aluminum, designed & manufactured in house at UTV INC in Mesa, Arizona.
Please view listed of machines below to see if yours is listed and this product will fit.
*WILL FIT 2019 XP1K/XP41K/XPT/XP4T/S900/S4900/S1000/TRAIL/DYNAMIX/XP TURBO "S" AND RS1*
This tool will work for the following FRONT & REAR WHEEL BEARINGS:
2015 Polaris ATV RZR 900 EPS TRAIL
2015 Polaris ATV RZR 900 XC EDITION
2015 Polaris ATV RZR S 900 EPS
2015 Polaris ATV RZR 4 900 EPS
2015 Polaris ATV RZR XP 1000 EPS HIGH LIFTER EDITION
2015 Polaris ATV RZR XP 4 1000
2016 Polaris ATV GENERAL 1000
2016 Polaris ATV RZR S 900 EPS
2016 Polaris ATV RZR S 1000 EPS
2016 Polaris ATV RZR 4 900 EPS
2016 Polaris ATV RZR XP 1000 EPS HIGH LIFTER EDITION
2016 Polaris ATV RZR XP 4 1000
2016 Polaris ATV RZR XP Turbo
2016 Polaris ATV RZR XP 4 Turbo
2017 Polaris ATV GENERAL 1000
2017 Polaris ATV GENERAL 4 1000
2017 Polaris ATV ACE 570 SP
2017 Polaris ATV ACE 900 EPS XC
2017 Polaris ATV RZR S 900 EPS
2017 Polaris ATV RZR S 1000 EPS
2017 Polaris ATV RZR 4 900 EPS
2017 Polaris ATV RZR XP 1000 EPS HIGH LIFTER EDITION
2017 Polaris ATV RZR XP 4 1000
2017 Polaris ATV RZR XP Turbo
2017 Polaris ATV RZR XP 4 Turbo
2018 Polaris ATV GENERAL 1000
2018 Polaris ATV GENERAL 4 1000
2018 Polaris ATV ACE 570 SP
2018 Polaris ATV ACE 900 EPS XC
2018 Polaris ATV RZR S 900 EPS
2018 Polaris ATV RZR S 1000 EPS
2018 Polaris ATV RZR 4 900 EPS
2018 Polaris ATV RZR XP 1000 EPS HIGH LIFTER EDITION
2018 Polaris ATV RZR XP 4 1000
2018 Polaris ATV RZR XP Turbo
2018 Polaris ATV RZR XP 4 Turbo
The 2014 bearing is the same size, but the part number is different. Not sure what the difference is. I do not have a 2014 model here, only a 2016 & 2017 to check fitment on. The bearings on those models only x-ref to the 2015 and newer models. At this time, we are not stating nor confirming it will work on 2014 or any other model than what is listed above until we can test fit here personally.
The 2014 bearing is the same size, but the part number is different. Not sure what the difference is. I do not have a 2014 model here, only a 2016 & 2017 to check fitment on. The bearings on those models only x-ref to the 2015 and newer models. At this time, we are not stating nor confirming it will work on 2014 or any other model than what is listed above until we can test fit here personally.[/QUOTE ]
I have the Holy Tools greaser which this looks like a fancier clone of. I have a 14 XP1K and a 16 XPT. The greaser from Holy Tools works on both. So I would believe this would most likely work on a 14 model as well. I do like the knurled gripping area and the price seems to be spot on.
The UTV INC bolt in front harness bar for the 2014+ RZR 4 units will allow you to attach the OEM Polaris Click 6 retractable seat belts into your RZR 4 seat side by side UTV. Includes sandwich plates and grade 8 hardware as shown. This Polaris Click 6 Seat Belt Bar will fit 2014 and newer...
Need a good bungie tie down spot? Check out our UTV INC RZR expandable anchor tie down tab. These are compatible with the Polaris Lock'n Ride RZR bed holes and can be configured in different locations to allow the ideal tie down spot!
$25 each
*Fits ALL Polaris RZR Models (570, 800, 900, 1000...
The UTV INC 30" Under Roof LED Light Bar Mounts for the stock Polaris RZR XP Turbo S roll cages offer an aesthetically pleasing look while keeping the light under the top of the roll bar to offer some extra protection. CNC laser cut and bent steel tabs offer a sturdy mounting platform for your...
The UTV INC Polaris RZR XP 4 Assault Roll Cage is designed to fit the 2019 and newer Polaris RZR XP 4 SXS models, including XP 1000, XP Turbo, and XP Turbo S. This cage is 6" lower for the front occupants, and 8" lower for the rear occupants.
This roll cage is constructed of 1.75" 0.095 DOM...
Wanting an easy attachment spot for your tie down hook on your Polaris RZR UTV model? This kit will give you 4 tie down spots on the suspension of your Polaris RZR UTV! Uses all stock hardware and bolts to the bottom of the shocks. Sold as a kit of 4.
Kit has been test fit on Polaris RZR XP...
