uni airfilter
2.6K views 9 replies 6 participants last post by  Denver
wondering if I put a uni on the 570 ace will I need to get a fuel controller??
I'd say no. Why a Uni though? I've not had any luck with them. Had a friend with a 900 Trail and his got dusted as well. Tried different oils, not sure what the problem was but I always found dirt in the intake.
I had bad luck with Uni on my RZR 800. They inhale the filter oil and coat the mass air sensor creating low or no idle.
wanting to open up airflow and exhaust. want to know if I open the factory exhaust and cut the baffles out if it will help or just sound terrible. looking for more get up and a little power without having to spend $300.
It's a proven fact in RZR that if you open up airflow you reduce filtration and you end up with no compression in a dusted motor. Top overhaul costs how much?
Lots of companies making slip on exhaust for more flow/less restriction. Everyone complains they're too loud and most go back to stock. I think HMF makes a muffler with a "quiet core" option but still a little louder than stock.
Stock intake still doesn't work so hot in silt, even with a pre filter. I have a uni filter too, but have yet to run it. I keep it for an emergency back up. My dad has a knn setup on his RZR800 and it's a PITA to service. I stay stock air filter, if I was gonna change it would likely be a dry media filter from AFE.
I'm running the Big Gun Exhaust, it's loud. But I like loud. YouTube video online, google Team Pistelak Exhaust
They had one more word: "dusted".
  • Like
Reactions: SpdBump
