Installed the SSV Works RZ5-1KRC kit in my 21 Pro XP 4 last week, integrated with Ride Command and the factory Ultimate RF stereo system. It has the Kicker sub, not the SSV works one. I'm underwhelmed by the bass output on this unit, wanted to see what other's experience has been.
It definitely adds some low end, and sitting in the passenger seat right in front of the sub you can actually feel it. However, anywhere else (driver's seat, outside the car, etc) it just doesn't have much volume. I've played with the gain settings and bass boost on the amp, and the equalizer in RC and just can't get much output.
Figured maybe it was normal, but I camped with a few others this past weekend and it was a night and day difference in bass output in their rigs. Theirs sound fantastic, mine is just ok. Both of them are running similar under-glovebox boxes. One of them I think is actually an SSVworks box. Both are Wet Sounds subs and amps.
Are my expectations just too high for this setup? Is the amp undersized, or am I doing something wrong? I've set up several sub/amp combos in boats and cars before, very familiar with gain, boost, crossovers, etc and what they do. Just not sure how much I should expect from this setup or if there's anything else I can try to get more output here.
