21 - 40 of 141 Posts
Discussion Starter #22
Re: "Under Cover" Clutch filter 1000
Any testing on this product yet for the air filter side? as a pre-filter?
We have one. We have not done enough testing on it yet in real time.
On the clutch we must worry about heat build up and the engine HP.
It's easy to measure the heat. Not so easy for HP.
Dunepilot
I can make them for a turbo. The turbo only has one intake. I have a die that can cut it with one intake. We have not tested them on a turbo. I can ship some like that Monday. Also for the double intake I can get out Monday as well it will just have added tabs to hold the small intake filter down. We have ordered a new die to make them all one piece and will not get it until mid week.
I have committed to several for Monday so a couple more will not matter.
Priority will get it there by mid week.
Definitely interested for the 2016 Turbo.
Thanks!
hi tim
i just ordered one of these under clutch cover filters
after watching your short video
this looks like it will be a good product
my colorado in state riding season won,t start till the spring so
i,d still like to read any feedback on people now using this product like clutch temps etc
thanks
Discussion Starter #35 (Edited)
Our filter gives approximately 130 sq inches of surface area for very low if any restriction. It gives exceptional filtration and should not cause unacceptable heat build up.
If anyone would like to get a cheap temp gauge go here. DC 12V F Fahrenheit Temperature Controller Thermostat Control 1 Relay NTC Sensor | eBay It is very easy to install and use. 14 bucks
I will put up some video of our temp testing soon.
http://wolfsnoutdustmask.com/shop/utv-accessories/utv-dust-clutch-filter/
Discussion Starter #36
Pls make one for the Ace too ( both sides if possible ) and let me know.
You should also register on aceforums.net ;-)
i received my pre clutch filter today
after examining it looks good just have to remember to clean it often
its pretty scary how much dust i blew out of the clutch housing in the past i can only see good results with this pre filter just need to remember to remove and clean filter after riding often
i will also be installing a drive belt housing temp probe to monitor drive belt exhaust temp
