1 - 5 of 5 Posts
Hello, I recently purchased an 08 RZR 800 with two batteries and an isolator between them. My question is should both batteries be grounded to frame or would this create a "multi point" grounding problem? Thanks.
The text book method would be to have both batteries grounded at the same spot on the frame. Will you ever see a difference if each is grounded at a sep location on the frame, (creating a ground loop) or wired as above....I doubt it.
Super Moderator
1 - 5 of 5 Posts
