1 - 12 of 12 Posts
· Premium Member
With all the talk about the new Ride Command, I wanted to share links to a few of our products and a little info.
We have Plug and Play Turn Signal Kits for 2017 RZR Special Edition Velocity Blue with Ride Command. These are custom made to fit only this model and plug into OEM connectors on Ride Command RZR wire harness.
****Please Note: There is a difference in wire harnesses between the factory equipped Ride Command RZR and non factory equipped. So if you or your dealer added Ride Command to your RZR, the wire harness is different. We have kits for both, if you have any questions, please ask.
Some model specific Plug and Play Turn Signal Kit links:
2017 Velocity Blue RZR with Ride Command
2015-2017 RZR 900 / 1000 / Turbo
2014 RZR 1000
See all our products at www.corbincustomworks.com
· Registered
I don't have this specific kit but I do have Corbin Custom Works turn signal and horn kits in my General. I can't speak highly enough about these guys. Seamless integration and just all around good peeps to deal with. They even worked with me on some truly "custom" requests for my turn signal kit.
· Registered
Just installed the signal kit in my XP1k Crawler Edition, easy to follow instructions with templates and pictures and a very well designed kit. Works great and looks factory, love it. I'd also recommend to anyone looking at this kit to add the cluster light option, it was simple to install and will keep you from forgetting to turn off the blinker.
· Registered
anybody use these kits?? They look great!! already have horn n license plate for S.D., just need the turn signals for Moab. Thanks for the replies.
I have had this installed for a month or better now, I was the one that pointed out the difference of wiring to them and they jumped on this right away and got a kit together in about two weeks. It arrived and I installed it the same day, very professional kit, easy to install and instructions and templates were spot on. Just ordered another one for a riding buddy with the same 2017 Ride Command machine.
Great company to work with
· Registered
Installed the Corbin "Fang" Turn Signal and Horn Kit on my 2020 RZR 4 XP 1000 Ride Command and the quality and ease of installation is second to none. Great quality on Fang lights, switches, module and all harnesses...EVERYTHING WAS PERFECT! Thanks again to Chris for answering all my questions before I purchased. Super fast delivery!
· Registered
2014 RZR 1000
I bought a turn signal kit from UTV Source for my ride command but the rear tail light plug is a 4 pin instead of an 8 pin. Is there an adapter out there that will work for this?
1 - 12 of 12 Posts
