1 - 20 of 47 Posts
After 4 calls to Polaris and me and my mechanic trying to figure out the winch situation I think we have finally made progress. There is a winch plate that comes on the S and looks to be a place to put the winch above the differential but it will NOT fit because of the radiator bracket. I finally spoke with someone at Polaris who was able to tell me about 2 new winches that will work. The part numbers are 2882240 and 2883828. Hopefully these will in fact work. I am going to order one and hope for the best. I did not want to run a front bumper and a winch is 100% necessary where I ride. There seems to be no info out there yet on this so I hope this helps someone out.
Here is the link to the new winches for the S.
https://rzr.polaris.com/en-us/shop/accessories/winches/2882240/
https://rzr.polaris.com/en-us/shop/accessories/winches/2883828/
The top one will not fit Order the bottom one and u need the bumper
Have you tried them both? Where does the second mount to a bumper at? Are you 100% positive neither will fit without a bumper? Frank, if you are reading this can you shed some light on this?
Have not tried them both the bottom one is back ordered The dealer spent seven hours Trying to get the top one in they were unsucesfull
I have money down on a Turbo S and just waiting for it to show up. Of course one of the first items I will add is a winch due to where I ride. Has anyone successfully installed a winch above the front diff yet. I am not crazy about the bumper mounted winches. Does anyone offer a winch bumper for the Turbo S yet anyway. Please post pics of item# 2883828 installed if you have any. It looks kinda funky.
Discussion Starter #10
auburnu008
What size winch was your dealer trying to install? Will a 2500# fit but a 4500# will not or does the size make no difference?
They were trying to put in a 4500. The motor would need to be at least 3/4" smaller in diameter for it to have a chance.
Unfortunately you want 2x minimum pulling power to weight ratio. My quads have 2500 and 3000 lb winches. I would think anything under 4k is just asking for trouble...and honestly, 4500 would be a much better choice. I hope they're able to make 4500s fit...otherwise, I'll just custom mount one out front or do a custom install with receiver hitch so it can go on the front or back.
Discussion Starter #14
That looks way better than I thought it was going to. I guess the bumper that Harts UTV mentioned above is optional. Sweet ride. I wish mine would get here. :sad
Yeah I agree. It looks like it sticks out a little more than it does in the picture. There is a thick bash plate around it so if it does ever hit any rocks or anything it should be ok.
Bottom one attaches to this bumper from polaris.
I have this bumper and an older multi mount Polaris (built by Warn) winch from my Ranger. Can I mount the old winch to this bumper? Obviously I would have to take the winch off the multi mount, but will it mount to the new Polaris bumper? I haven’t really looked at the bumper very closely to see if it has attachment points built into it (I don’t have access to my machine right now to experiment).
1 - 20 of 47 Posts
