1 - 4 of 4 Posts
is there a kit for all the bearings and seals for the transmission and transfer case? bought a basket case that needed a motor and decided to pull apart the transmission and rear diff and the transfer case had no oil just water in it, so it needs all the bearings.
Discussion Starter #2
I dont know if anyone cares but I priced all the bearings from partzilla for it and it was gonna be well over $400. I got all the part numbers for the bearing and cut that down alot so if your rebuilding heres the main bearings youll need, this doesn't include any of the numerous needle bearing assemblies, bearing shims, or any of the seals. I haven't been able to find the seals outsourced. maybe someone else knows? most are made by TTO so a china company.
You can get these bearings either really cheap CHINA or high quality bearings of your brand preference. Timken, SKF, NTN Etc.
Quanity - Bearing number - OEM number
_4____6205______3234502
_1____6204______3234549
_1____6305______3234545
_2____LM11910___3234556
_2____LM11949___3234557
_1____15520_____3234562
_1____15590_____3234563
_1____LM11749___3234565
_1____LM11710___3234566
3235080 and 3234563 both cross reference to 15590.
3234563 is a Timken (USA) bearing used in 2008 & 2009
3235080 is Peer (China) bearing used in 2010 thru 2014
  • Like
Reactions: gsbuick65
1 - 4 of 4 Posts
