1200 RPM
From shop manual:
Poor Idle
Symptom: Idle Too High (If greater than 1300 RPM when engine is warm).
•Throttle stop screw set incorrect
•Throttle cable sticking, improperly adjusted, routed incorrectly
Also found:
Check the following items when shifting difficulty is encountered.
•Shift cable adjustment/condition
•PVT alignment (clutch center distance)
•Idle speed (throttle cable routing)
•Transmission lubricant type/quality
•Loose fasteners on sector gear cover
•Worn rod ends, clevis pins, or pivot arm bushings
•Shift selector rail travel
•Worn, broken or damaged internal transmission components
NOTE: To determine if shifting difficulty or problem is caused by an internal transmission problem, isolate the transmission by disconnecting the shift cable end from the transmission bellcrank. Manually select each gear range at the transmission bellcrank, and test ride vehicle. If it functions properly, the problem is outside the transmission.
If transmission problem remains, disassemble transmission and inspect all gear dogs for wear (rounding) or damage. Inspect all bearings, circlips, thrust washers and shafts for wear.
