Bought a 2010 RZR-S when I went to drain all of the oils I found that a fine thread bolt was screwed into the transmission with some JB Weld? What is the recommended (in Place) fix for this? Drill and Tap to 3/8 NPT or is their something better?
well said.time sert sells some of the countersink bits. Just make sure you don’t over do it since if you don’t have the right size and depth your gonna have a constant leakGood info, If it’s an o ring seal it will need a chamfer or counter bore machined in to accept the o ring. But if the top of the hole is machined flat you could switch up and use a flanged bolt with a soft washer, (copper or aluminum) for the seal.
