Your local powder coating shop should be able to powdercoat both a hitch and a stinger like this for about $20 in just about any color you want. The new Generation of Powder Coating is not only tough but now days its also flexible and comes in like 200 colors including metallics, pastels, and even imeron-looking colors.
Another nice feature is that because the thunderhawk hitch is a regular (albeit VERY heavy duty) 2" receiver hitch, I can also quickly throw in a regular 2" stinger to move my Waverunner or SxS Trailer around the yard. The Thunderhawk hitch also serves as a double-shear rear radius rod and frame brace, and tie down point. It's the only hitch I fount that mounted that high and also secured at108 mounting points, the four radius rod bolts plus both above and below. Some of them only bolted to the radius rod bolts, a few mounted to those and either the upper or lower frame but only Thunderhawk attatched at all 10 points with HD hardware. You can also still easily check/change/refil your fluid with the Thunderhawk hitch.
Oh yea, and I call my rear hook my "Commander Hook" because the first several things it was ever used for was to pull out my buddies CannedHam Commander.
