Torque Specs
1 reading
18K views 7 replies 6 participants last post by  HoustonHayseed
I'm replacing a rear axle and need a few torque settings. Anyone know what the torque is for the axle castle nut, brake rotor and upper radius rod? It's on a 17 XP4 Turbo.
Just a FYI, those are not correct for a 17 turbo. Castle nut is 180, front caliper is 30, rear is 42 and radius rods are 100. That's a big jump from the 16 turbo which was 42. Not sure why it went so high, nor the castle nut which used to be 110. But then I thought 120 was really high for the small wheel studs, so what do I know.
I have a 2017 Rock Crawler edition and a service manual for the 2017 xp1000. The master torque specification on page 1.8 also specifies 180 ft. lbs. for the castle nuts. I believe that is a possibly a misprint. In several other places in the service manual it specifies that the torque for the castle nut is only 110 ft. lbs. On both pages 7.13 and 7.15 it list the torque as 110 ft. lbs. for both the front and rear castle nuts.
