Torn A-Arm/Control Arm Mounts!!! What Do I do???
4.9K views 17 replies 14 participants last post by  nvpowerdoc
My front lower A-Arms ripped right out of the thin mounting points on the frame. Are there any aftermarket mounts available or do I have to make some?
HELP:scared2:
time to pull out the mig i have washers welded on to make em stronger they never broke but i dident give em the chance
#15 ·
I was at camp when it happend, but it looked like they came off the dune and landed in a big hole on the left side. I had already stressed the front end some from my crash the night before, but it was driving fine before they landed in that hole.
That will be the last time someone drives my machine when I'm not in it:scared2:
Sorry man but isn't this how it seems to go. Either by dump luck, or they don't care cause it's not theirs. Is the rest of the frame straight?
Jason
The rest of the frame is fine. It bent the front A-arms a little, bent the passenger side A-arm mounting bolt(mounting tabs are fine), and sheared the bolt and ripped the mounts on the drivers side.
I now have new A-arms, A-arm bolts, tie rods, bushings, gusset kit, frame reinforcement kit, A-pillars w/braces, and a new cage on the way.
Expensive weekend:scared2:
