2013 Xp 4 900. Tires are 27x9-12and 27x11-12. I want to increase size to 29”. Any suggestions on what to do? I’ll even buy used rims and tires. I have 1800 miles on it and was told by the dealer that at 2000 to put an entire new clutch on it. Is that true? Do I need to reclutch with bigger tires? I ride 6000-12000 elevation. Thanks
If your main riding is on tight trails in low then you simply drive on a road at higher speeds to the next trail I would say no kit needed, the kit comes into play when you are a on and off the throttle person and lost power due to tires.
I have a 2013 900xc and put 30 inch terrabites on with Hunterworks rollers and belt. Do mostly trails/desert I would say 75 percent low range, then the rest desert getting there in High. just got back from Moon Rocks in Nevada and no problems with clutching.
Related Threads
Polaris RZR Forum - RZR Forums.net
3.1M posts
141.7K members
Since 2007
A forum dedicated to Polaris RZR enthusiasts! A great place to find rides, meet people, and exchange ideas / parts/ rzrs!
