1 - 6 of 6 Posts
hello in rzr land I just put a set of titan 589mt's on my rzr 27" they are 6 ply with a very heavy sidewall and are stamped 7psi max just wonderimg if anyone has a set or wants to put in there 2cents about what I should be running for pressure we travel woods trails [rocks stumps etc.]and of course swamps and snow all winter thanks
Ewan, I'm really suprised that there is a set of 6plys out there with a 7# Max. Do they say why or does their website say why???
The stock #'s for the RZR is 8#s and for trails, that is usually were I start. If you heat them up they get up to 10-11#'s
John
Johnpeq, are you saying that the tires should be aired up more or less than 7# ?
I am running 27" swamplites on mine and I was runnin low around 5 just for extra traction. Everything is all great until you get goin a little and hit a rock and pinch your tire in 2 spots.
I am running em around 7.5#'s now but have yet to ride them. Im sure its going to make a hella difference in comfort but I am wondering if I can go even more? I just hate to keep poppin tires. Tire says 7lbs max and 15# to set bead....
Ewan let me know what you think about those tires.....I have been lookin into em as an extra set. what kind of riding do you mainly do?
dont know why it is max 7# they have built in rim gaurds and I can let all the air out and they only look low so know I am trying 5# all around 7# was to hard I was spinning on any semi hard surface. I ride mostly rocks stumps swamps and woods trails
i now ride with 10 psi in my tires. i have had to different set of front tires pop off the rim when turning at 7psi. i have since put on twice the miles with the 10psi and no problem when playing hard in the mud, rock or dirt. yes the ride may have gotten a bit stiffer but it sucks changing tires on the trail!
in the winter i run 5psi for more tractionn in deep snow
1 - 6 of 6 Posts
