1 - 3 of 3 Posts
· Registered
Hi all,
I want to remove the 1" spacers on my 28" BigHorms to see if it stops front wheele-well rubbing. The tire is about 1/2" from motor mount when spacer removed. Is this safe? :popcorn:
Thanks for any input,
alrzr
· Registered
If it is when fully lifted off the ground at full droop you should be fine. I ran mine with only 1/4" of clearance off the motor mount for over a year and jumped it regularly without any problems. When you are cornering and the tire is peeling inward on the rim. Your suspension is usually compressed and at that point you are along ways from the tire.
· Registered
Thanks for your input.
Well I took out the spacers and the tire hit the mount when fully lifted.
I ground down the motor mount and when not lifted looks like 1/2"
Looks like I should be good.
alrzr
1 - 3 of 3 Posts
