I just fixed mine. It was puking fluid out. I took it off, drained all the fluid out of it. Took the top section with the lowering handle off, then the jam nut under that, then the plastic boot. I then reinstalled it and made a file mark on the rod where I wanted it to stay. Back off and then welded the rod in place, cooled it off, put the plastic sleeve on, jam nut, and the lowering top with out the handle "obviously", and reinstalled. Good and tight and no more worries.
If a guy wanted to, you could take off the two allen bolts on the main swivel section, take off the plastic washers off and tighten them up really tight also. I am a big guy, have Pro Armor doors on and I have no problem getting in and out with the Steering Wheel in the normal driving position. And now I know it won't freeze up straight up, down or puke out on me on the trails!!
Tilt would have been a good option if Polaris had put on some quality shocks on, but reading and knowing how many I have seen go bad, it is a no brainer to secure it solid. Goodluck!!
NOTE!!!!!!!!! I should have stated, that if yours has the fluid in it, drill a hole in the bottom and drain out before welding the rod in place!!!!!!! NOTE!!
Mine had all the fluid come out thru the release pin, and I just kept on pumping it till all was gone, but in reality the amount of weld to secure it in place is so little and so fast that a guy probably should not be concerned of building up excess gas in side the shock, but to be sure just DRILL A HOLE AND DRAIN IT!!!
