1 - 3 of 3 Posts
Did Polaris leave slack in the throttle cable? I heard when at "wot", it's still only at around 75 percent. If this is the case do you adjust it at the engine or at the pedal?
There is an adjustment on the throttle cable near the throttle body depending on what you are driving. Cables naturally stretch over time. There is a lock nut that you loosen make the adjustment and retighten the lock nut. This is adjustment is much like a cable on a motorcycle.
1 - 3 of 3 Posts
