There was several changes made from 2010 to 2011 models (to the best of my knowledge). I believe that was the year they changed the front grill area to allow more air to the radiator and the drive shaft changed (added middle carrier bearing). I think my 2010 model gauge allows you to flip between hours, miles, and rpm if I'm not mistaken.
I have been interested in adding gauges myself. So here is some stuff I have found looking around at, but have not bought anything yet.
Looking at adding water temp, oil pressure, volts, and belt temp gauges. This stuff can get expensive quick, so I dunno.
Pod (these guys sell gauges as well)
Looking to install some gauges on your RZR but don't want to cut your dash up? Here is your solution!
teamalbaracing.com
Rocker switch panels
This 5 hole center mounted dash panel and (2) single hole panels fit every single RZR XP 900, 800 and 570 made from 2008 to 2014 (also fits 2015 RZR 570). Switch plates include Stainless Steel button head mounting hardware with stainless steel washer and nylon lock-nut.
www.ebay.com
Another thread talking about similar....
Does anyone know if it is possible to install a oil pressure gauge (electric or mechanical) on a RZR 800?? Thanks, Bunkysdad
www.rzrforums.net
I'm not sure yet which route I will take yet. I'm looking for more cost effective routes to get the job done. I may have to settle for less in the end as well.
