As some of you may know we are currently finishing turbo systems for four different 2011 snowmobiles and have several other vehicles on the way from their manufacturers that need to have systems developed so we need to make some room. Our RZR-4 barely gets used outside of going to shows and taking people for rides so it's first on the list. Here's the breakdown:
2010 RZR 4-Seater
-Robby Gordon Edition
-Less than 300 miles
-Garaged
-Cleaned after every use
Aerocharger Stage-3 Turbo Kit:
-53 SERIES AEROCHARGER
-Turbine Heatshield w/ Insulator
-Gibson Stainless Steel Full Exhaust System
-AEM Wideband Oxygen Sensor and Gauge
-AEM Dry-flow Air Filter
-VDO Boost Gauge
-Aerocommander Fuel Controller Box
-EPI Custom Clutch Kit
-Bosch Blow-Off Valve
-Billet Throttle Body Adapter w/ 3rd Injector Assembly
-Custom Fuel Lines
-Exhaust Gaskets & Springs
-Hard Anodized Mandrel Bent Aluminum Charge Tubes
-TIG Welded, Nickel Plated Turbo Cradle Assembly
-TIG Welded, Hard Anodized Intake Sensor Block
-TIG Welded, Polished Air/Water Intercooler
-Bosch Water Pump
-Secondary Radiator & Hood Scoop
-Custom RZR Bed Heat Shield
-Donaldson Cannister Filter Upgrade
Currently the turbo is set for 6psi to run pump gas but we can set the boost anywhere you like and even tune it for your desired boost level at no extra cost.
$17,500
Call: (913) 541-0200
Email: [email protected]
2010 RZR 4-Seater
-Garaged
-VDO Boost Gauge
-Custom Fuel Lines
-Bosch Water Pump
$17,500
