1 - 2 of 2 Posts
On a 2019 rzr xp 1000. Was flipped on passenger side and got running again but still stuttering. Assuming it’s bad stuff in the tank what’s the easiest way to remove tank or at least drain completely to clean out. And also how to check fuel filter? Thanks
Fuel filter is part of the fuel pump. Pull passenger seat, unhook fuel line and connector. Spin collar off and the fuel pump comes out of the tank. Filter/sock is on the assembley fuel pickup. You can also acces the tank this way to siphon the gas out.
Sent from my SM-G965U using Tapatalk
1 - 2 of 2 Posts
