81 - 93 of 93 Posts
Discussion Starter #81
NEW OEM Polaris Parts unless noted (***) for your XP 900 or XP 900 4 Engine...
1) Head Gasket (1) $35.00
2) Base Gasket (1) $20.00
3) Water Pump (1) $160.00
4) Oil Pump (1) $190.00 (2011-2012) (1) $170.00 (2013-2014)
5) Oil Pickup Tube (2 ) $40.00 (2011-2012) (1) $20.00 (2013-2014)
6) Oil Pump Seal (1) $30.00 (2011-2012) $5.00 (2013-2014)
7) Crank Flange Seal (1) $23.00
8) Cylinder (1) $420.00
9) Rod Bearings (4) $32.00
10) Main Bearings (8) $72.00
11) Counter Balancer Bearings (4) $32.00
12) Pistons, Rings Wrist Pins and Cir-Clips (2 sets) $220.00
13) Crank (1) $700.00 (2011-2012 (1) $750.00 (2013-2014)
14) Complete Machined Exchange Head (1) $550.00 (ready to install with cams, shimmed, ETC) (usable complete head core required or extra core charge is applied)
15) Oil Cooler O-Rings (2) $8.00
16) Head Bolts (6) $78.00
17) Exhaust Gaskets (2) $30.00
18) Water Inlet Gaskets (2) $18.00
19) Stator Cover Gasket (1) $25.00
20) Cam Gear Bolts (4) $12.00
21) Spark Plugs (2) $10.00
22) Oil Filter (1) $12.00
23) OEM Tensioner (1) $65.00
24) Mechanical Tensioner (1) $140.00 ***
25) Cam Shim Kit (1) $90.00 ***
26) Oil (4 qts) $40.00 (2011-2012) (3 qts) $30.00 (2013-2014) ***
Pick and choose the parts you need!!!
Total Of Parts + Shipping... I ship FedEx Insured to the Lower 48 States...
Discussion Starter #82
Discussion Starter #83 (Edited)
13) Crank (1) $730.00 (2011-2012 (1) $780.00 (2013-2014)
Discussion Starter #84
Discussion Starter #85
Discussion Starter #86
Discussion Starter #87
Discussion Starter #88
Total Of Parts + Shipping... I ship FedEx to the Lower 48 States...
Discussion Starter #89
Discussion Starter #90
Discussion Starter #91
Discussion Starter #92
Discussion Starter #93
81 - 93 of 93 Posts
