21 - 35 of 35 Posts
Discussion Starter #21
Shim-Under-Bucket Conversion Kit is a simple solution to the costly task of adjusting the valves on any RZR XP 1000 engine. To do a valve lash adjustment you must buy different sized buckets with built in shims, if your off on size you get to buy more buckets @ $30.00 a piece. The Shim-Under-Bucket Conversion Kit is a one-time installation which allows you to make simple valve lash adjustments with a shim change.
Kit Includes:
(8) Valve spring retainers
(8) Valve buckets
$260.00 Shipped FedEx Insured to the Lower 48 States !!!
*** Shim Kit Available for $90.00 includes shipping when shipped with TAGTEAM Shim-Under-Bucket Conversion Kit ***
Discussion Starter #22
Kit Includes:
(8) Valve buckets
Discussion Starter #23
Kit Includes:
(8) Valve buckets
Discussion Starter #24
Kit Includes:
(8) Valve buckets
Discussion Starter #25
Kit Includes:
(8) Valve buckets
Discussion Starter #26
Kit Includes:
(8) Valve buckets
Discussion Starter #27
Kit Includes:
(8) Valve buckets
*** Shim Kit Available for $90.00, includes shipping when shipped with TAGTEAM Shim-Under-Bucket Conversion Kit ***
Discussion Starter #28
Kit Includes:
(8) Valve buckets
Discussion Starter #29
Kit Includes:
(8) Valve buckets
I'm interested in buying a kit with shims. Do you have a website to order from? Do you produce these or are they a different brand?
Tim hasn't posted on here since April. I suggest you try to give him a call at (928) 273-4249.
Mine wouldn't start at all and when I measured my valves, they were so tight I couldn't get a gauge between the bucket and the cam. I ended up getting a Bikeman performance kit and it was garbage. All it was were 900xp buckets and spring keeps and a hot cams shim kit that had the wrong size shims so i ended up having to buy shims.
21 - 35 of 35 Posts
