1 - 2 of 2 Posts
Rebuilt 2013 Jagged X Engine Wet Sump Engine... Rebuilt with OEM Parts... This engine will fit in either a Jagged X 2013 or 2013 XP 900 or 2013 XP 900 4 or 2014 XP 900 or XP 900 4...
1) Head Gasket (1)
2) Base Gasket (1)
3) Oil Pump Seal (1)
4) Oil Pump (1)
5) Oil Pickup Tube (1)
6) Oil Pump Chain (1)
7) Cam Chain (1)
8) Crank Seal (1)
9) Valve Cover Seal (1)
10) Main Bearings (8)
11) Counter Balancer Bearings (4)
12) Rod Bearings (4)
13) Pistons, Rings Wrist Pins and Cir-Clips (2 sets)
14) Stator / Ignition Cover Gasket (1)
15) Water Inlet & Thermostat Base Gaskets (2)
16) Exhaust Gaskets (2)
17) Head Bolts (6)
18) Case Sealant (1)
19) Cylinder (1)
20) Crank (1)
21) Head Decked, Valve Job (1)
22) Mechanical Chain Tensioner & Gasket (1)
23) Oil (3 qts.)
24) Oil Filter (1)
$3950.00 Shipped to the lower 48 States...
Discussion Starter #2
1) Head Gasket (1)
2) Base Gasket (1)
4) Oil Pump (1)
7) Cam Chain (1)
8) Crank Seal (1)
17) Head Bolts (6)
19) Cylinder (1)
20) Crank (1)
23) Oil (3 qts.)
24) Oil Filter (1)
1 - 2 of 2 Posts
