101 - 120 of 126 Posts
Discussion Starter #101
TAGTEAM Mechanical Tensioner XP 900 or XP 1000 $140.00 Shipped To The Lower 48 St
TAGTEAM Mechanical Tensioner XP 900 or XP 1000...
$140.00 Shipped FedEx Insured to the lower 48 States...
Very EASY to Install ... Takes approximately 1/2 to 1 hr from start to finish...
Instructions are for either XP 900 or XP 1000:
1) Blow out the Spark Plug Holes and The top of the Valve Cover
2) Remove the Valve Cover
3) Remove the Spark Plugs
4) Remove the Clutch Cover
5) Rotate the Primary Clutch "COUNTER CLOCKWISE ONLY" (Never Turn Engine
Clockwise) until the (E's) on the Exhaust Cam Gear and (I's) On the Intake Cam Gear line up horizontal with the top edge of the head
6) Verify TDC (Timing Mark is on the flywheel)
7) Remove the stock tensioner
8) Put a very minute amount of sealer on the Mechanical Tensioner threads
9) Remove your metal seal from the stock tensioner and install it on the Mechanical Tensioner
10) Thread the Mechanical Tensioner all the way into the cylinder and tighten the tensioner with a wrench
11) Tighten the center adjuster bolt as far as you can by hand then turn it another 1/4-1/2 turn more with a wrench and tighten the lock nut with a wrench
12) Visually check to make sure the Cam Chain is in the gear teeth and seated correct
13) Rotate the Primary Clutch "COUNTER CLOCKWISE" 1 full revolution to make sure cam chain is properly engaged with the gears
14) Re-Install the Spark Plugs
15) Re-Install the Valve Cover
16) Re-Install the Clutch Cover
17) If the Mechanical Tensioner is LOOSE it'll make a slapping noise on start up (re-adjust the tension )
18) If the Mechanical Tensioner is to TIGHT it'll make a whining noise (re-adjust the tension)
Go ride !!!
Discussion Starter #102
Go ride !!!
Discussion Starter #103
Go ride !!!
Discussion Starter #104
Go ride !!!
Discussion Starter #105
Go ride !!!
Discussion Starter #106
Go ride !!!
Discussion Starter #107
Go ride !!!
Discussion Starter #108
Go ride !!!
Discussion Starter #109
Go ride !!!
Discussion Starter #110
Go ride !!!
Discussion Starter #111
Go ride !!!
Discussion Starter #112
Go ride !!!
Discussion Starter #113
Go ride !!!
Discussion Starter #114
Go ride !!!
Discussion Starter #115
Go ride !!!
Discussion Starter #116
$140.00 Shipped FedEx to the lower 48 States...
Go ride !!!
Discussion Starter #117
Go ride !!!
Discussion Starter #118
Go ride !!!
Discussion Starter #119
Go ride !!!
Discussion Starter #120
Go ride !!!
