61 - 80 of 80 Posts
Discussion Starter #61
Holz XP 1000 Billet Motor Mounts
Fits 2014 - 2016 RZR XP 1000 & XPT
$200.00 Shipped to the lower 48 States...
Installed on the TAGTEAM XP 1000 :) :) :)
Discussion Starter #62
Discussion Starter #63
Re: Holz XP 1000 Billet Motor Mounts
Just got a set , when I get them and install them I'll let you know how they, feel will be out in ocatillo for new years be a good test. Since holloween I've had a small vibration when getting on the throttle feels like the engine trying to twist in the mounts hopefully these take care of it
Plus they are way better built and looking than the stock junk
Discussion Starter #65
Just got a set, when I get them installed I'll let you know how they feel, will be out in Ocotillo for New Years, that'll be a good test. Since Halloween I've had a small vibration when getting on the throttle feels like the engine trying to twist in the mounts hopefully these take care of it
Your Holz Billet Motor Mounts shipped yesterday, you should have them by Thursday...
Thank you...
Discussion Starter #66
Discussion Starter #67
TAGTEAM - Holz XP 1000 Billet Motor Mounts
Discussion Starter #68
Discussion Starter #69
Discussion Starter #70
Discussion Starter #73
Discussion Starter #74
Discussion Starter #75
RZR XP 1000 HD BILLET MOTOR MOUNT KIT
MSRP: $199.95
The only complete HD Motor Mount kit available for the RZR XP 1000!
The Holz Motor Mounts are made using CNC machined 6061 Billet aluminum housing and incorporates a stout poly-graphite urethane isolator to limit vibration and decrease deflection.
This is a direct bolt in kit and does not require any modification for installation.
Sold in sets of 3
Kit Includes:
1) (3) HD Billet Mounts With Poly-Graphite Inserts
2) (2) HRP Trans Mounting Brackets + Hardware
3) (1) Instructions
Install the Holz Motor Mount Kit to prevent potential damage to your motor, diff or transmission cases.
The stock rubber damped motor mounts have shown to be weak and tear over time- especially under heavier loads or aggressive driving. The soft rubber allows the engine, transmission and rear diff assembly to move or deflect too much and cause damage.
What is Poly-graphite and why do we use it?
Poly-graphite is polyurethane that has been impregnated with graphite so that it becomes self lubricating and eliminates that annoying squeak that you would get with other rubber or poly bushings. The polyurethane bushings are more rigid therefore much better at absorbing the twisting motion of the motor under load than traditional rubber, but is still forgiving enough to keep the smaller vibrations to a minimum.
Fits 2014 RZR XP 1000 & RZR 570
Do these still ship with the trans brackets? I called Holz but the girl helping me seems to think that only the XP 900 kit comes with brackets anymore.
Discussion Starter #77
MSRP: $199.95
Sold in sets of 3
Kit Includes:
3) (1) Instructions
They no longer have them. I do have 1 set with the bracket left.
MSRP: $199.95
Sold in sets of 3
Kit Includes:
3) (1) Instructions
PM sent
Discussion Starter #79
Discussion Starter #80
61 - 80 of 80 Posts
