681 - 689 of 689 Posts
Discussion Starter #681
TAGTEAM Complete Parts Kit For 800 Engine Overhaul
These are all NEW OEM Polaris Parts unless noted for your RZR, RZR S and RZR 4 "800" Engines...
1) Head Gasket (1) $35.00
2) Base Gasket (1) $22.00
3) Mag / Access Gasket (1) $18.00
4) Oil / Water Pump (1) $120.00
5) Oil Pickup Tube (1) $22.00
6) Oil Shaft Seal (1) $28.00
7) Crank Seal (1) $21.00
8) Flange Seal (1) $13.00
9) Water Pump Seal (1) $48.00
10) Main Bearings (2) $45.00
11) Counter Balancer Bearings (4) $85.00
12) Pistons, Rings Wrist Pins and Cir-Clips (2 sets) $200.00
13) Oil (2 qts) $25.00
14) Oil Filter (1) $12.00
15) Dowel Pin (1) $5.00
16) Spring (1) $5.00
17) Spark Plugs (2) $8.00
18) Lifters (4) $50.00
19) Push Rods (4) $115.00
20) Cylinder (1) $420.00
21) Crank (1) $500.00 (Aftermarket) $750.00 (OEM Crank)
22) Valve Job (1) $400.00 (Usable Exchange Complete Head Core Required)
23) Valve Seals (2) $45.00
24) UTVINC Billet Breather (1) $40.00
Pick and choose the parts you need!!!
Total Of Parts + Shipping... I ship FedEx Insured to the Lower 48 States...
Discussion Starter #682
Discussion Starter #683 (Edited)
1) Head Gasket (1) $38.00
2) Base Gasket (1) $23.00
3) Mag / Access Gasket (1) $20.00
4) Oil / Water Pump (1) $140.00
7) Crank Seal (1) $23.00
8) Flange Seal (1) $25.00
9) Water Pump Seal (1) $50.00
10) Main Bearings (2) $48.00
11) Counter Balancer Bearings (4) $95.00
12) Pistons, Rings Wrist Pins and Cir-Clips (2 sets) $225.00
15) Dowel Pin (1) $6.00
16) Spring (1) $6.00
18) Lifters (4) $55.00
19) Push Rods (4) $120.00
20) Cylinder (1) $430.00
22) Valve Job (1) $445.00 (Usable Exchange Complete Head Core Required)
23) Valve Cover Seal (1) $8.00
24) Asembly Lube (1) $10.00
25) HO Cam (1) $240.00
26) Counter Balancer (1) $200.00
27) Counter Balancer Woodruff Key (1) $10.00
28) Crank Woodruff Key (1) $10.00
29) Case Sealant (1) $10.00
30) Cases (1) $800.00
31) Water Pump Impeller (1) $30.00
32) Water Pump Cover Seal (1) $15.00
33) Stator Cover Seal (1) $18.00
34) UTVINC Billet Breather (1) $45.00
Total Of Parts + Shipping... I ship FedEx to the Lower 48 States...
Discussion Starter #685
12) Pistons, Rings Wrist Pins and Cir-Clips (2 sets) $230.00
13) Oil (2 qts) $20.00
22) Valve Job (1) $475.00 (Usable Exchange Complete Head Core Required)
30) New OEM Cases (1) $800.00
Total Of Parts + FedEx Shipping to the Lower 48 States...
Discussion Starter #686
34) UTVINC Billet Breather (1) $45.00 *** AFTER MARKET ***
Discussion Starter #687
Discussion Starter #688
Discussion Starter #689 (Edited)
These are all NEW Parts for your RZR, RZR S and RZR 4 "800" Engines...
4) Oil / Water Pump (1) $160.00
9) Water Pump Seal (1) $60.00
12) Pistons, Rings Wrist Pins and Cir-Clips (2 sets) $260.00
21) Crank (1) $600.00
24) Assembly Lube (1) $10.00
Total Of Parts + Shipping ...
