1 - 11 of 11 Posts
· Registered
Discussion Starter · #8 ·
I mounted mine right behind the steering wheel against the firewall.
where are you guys running the pink and white wire? Since the acc is a plug now.
Thank you
The white gets tied to the ignition, unless you want to do some trickery, but I cant see any reason to not have the panel lit all the time. I didnt use the pink since theres nothing I want to trigger. Idid notice the app bypasses the ignition being on which at first I thought was a problem, but now I see its kind of a neat feature.
· Registered
2022 Rzr Pro XP Ultimate
On the RCR Force 12 the light blue is connected to the Ignition and the Pinks are used as additional input triggers.
Rectangle Slope Font Parallel Circle
· Registered
Thank you!!
· Registered
I mounted mine behind the driver seat on my pro xp. Ran all the wiring in the rocker panel and mount the switch to the top of the roll bar. Makes it real easy to add wires to. Couple screws pulls the rocker panel or drop the skid plate.
1 - 11 of 11 Posts
