1 - 10 of 10 Posts
Welp, need some advice. Oddball clunks. Nothing I can tell is loose. Pulled wheels and shocks, nothing loose. Maybe spring spacer, a little play. Suggestions?
2015, 3500-ish miles. Garage Products bushings everywhere but the shock eyes.
The stock fox shocks on mine and a buddy's started to make a weird clunk at about the same mileage, around 3000 miles, both 2015's. Checked shocks, everything seemed tight, replaced bushings but clunk was still there, was driving us both nuts..
Turns out the shocks had lost preasure and were in need of a revalve. Sent our shocks off to shock therapy for a full rebuild and sure enough, no more clunk.
Good point. I've already done the Schmidty cap replacement and checked that.
What is the situation that causes the clunks. Full droop? Full compression? Front/Rear?
Discussion Starter #6
Just normal trail riding, minor bumps. Not consistent. I think it's the rear. No stones stuck anywhere.
I think I'm going to have to put my GoPro on a stick and take a local ride.
I'd remove the rear sway bar. It is easy to do.
If the cluck is still there....
Then, trade sides with the shock/spring assembly?
See what happens.
Slick Rock Red
My 2015 900s makes a clunking sound too. Sounds like something is rattling around in the drive train(?) I've replaced the axles, then the bushing under the secondary clutch, (Ads/Triple S did the work) Then I replaced the belt. Still no dice. I would like to know what you find out.
Discussion Starter #10
1 - 10 of 10 Posts
