1 - 10 of 10 Posts
Standard Vendor
We run SATV's long travel kit that uses the 7/8" i.d. Uniball set up on our play/race RZR. They have proven to be fairly tough except for the pin assemblies. They tend to get loose after very little use, the lip tends to roll over and due to their design there is no tightening them once this happens. Beyond that we found them difficult to service and remove from the ball.
Key Features include.....
Harder base material (Pre- heat treated 4140)
Redesigned mounting lip (For more surface area and strength)
G-9 12 point bolt (For superior strength and ease of service)
5/8" wrench notch (for easy installation and removal)
644069
644070
Standard Vendor
Discussion Starter #2
These are for the XP1000/ Turbo kits, but may fit others.... If you have any questions about dimensions they can be found on our desertcraft.us site.
Standard Vendor
We know there is a lot of kits out there running this style.... Where are you guys?
Standard Vendor
Super ATV was kind enough to reach out to us and confirm fitment.... Our Pin Assemblies will fit any of the "Atlas Pro" Boxed arms that utilize the 7/8" i.d. Uniball on the following models.
RZR XP1000, RZR Turbo, RZR 900S, RZR 1000S, Polaris General, Kawasaki Terex , Older style Yamaha YXZ.
Thanks
Standard Vendor
High quality pins using the best materials. Made in the USA!
Standard Vendor
Discussion Starter #6
excellent upgrade for your SATV arms!
Standard Vendor
Discussion Starter #7
Just had two participants running our Pins at the 2020 King Of The Hammers with zero issues! Brutal course this year, but our Pins were up to the task.
Standard Vendor
Discussion Starter #8
Superior Pin Assemblies for your Super ATV "Atlas" Boxed arms! Redesigned for strength, durability and easy service. Get yours today!
Standard Vendor
Discussion Starter #9
If you run the Super ATV Atlas Boxed arms with the 7/8" i.d. Uniball you need this upgrade!
Standard Vendor
Discussion Starter #10
We know that there are a lot of these style arms out there from Super ATV.... what is your experience?
1 - 10 of 10 Posts
