1 - 19 of 19 Posts
craigstumph
Contact Craig through a PM or conversation for your best deal on Rhino Prop Shaft.
Get a Prop Shaft That’s Built for Battle
Rhino Driveline Prop Shafts are the only prop shafts that are strong enough to handle every ounce of power your Polaris RZR XP Turbo can put out. Maximized shafts paired with U-series U-joints that wear less and run smooth mean it can withstand tons of torque. Bolster your driveline’s backbone with SuperATV’s expertise. Upgrade to a Rhino Driveline Prop Shaft and drive your Polaris RZR XP Turbo like you never could before.
Superior Construction
We built Rhino Driveline prop shafts with .120” tube walls and a 1.75” diameter tube. That’s bigger and thicker than your OEM prop shaft. It’s made of chromoly steel alloy unlike your OEM carbon steel prop shaft. That makes it strong enough to take on creeks, rocks, mud, and hills. It’s built for the way you ride.
C-Series
For ultimate strength and protection, get a C-Series prop shaft. The C-Series uses a CV joint built with a chromoly cage, spider, and cup, just like an axle, for superior strength. The high-quality boot keeps out mud, water, and dirt. The constant velocity of the CV means no rattle, wobble, or balance issues are possible. It’s the ultimate joint, and the smart choice for any ride style.
U-Series
U-Series U-joints are built like your stock U-joints but stronger. The U-Series uses needle bearings, just like OEM, but are made with a superior 4340 chromoly steel body. They’ll last longer and make it through tougher rides than a stock U-joint.
Carrier Bearing with Remote Grease Line
Rhino Driveline Prop Shafts are compatible with SuperATV Carrier Bearings only. Don't worry, they're the best you can get, and you can save when you bundle with your Rhino Driveline Prop Shaft.
Our Heavy-Duty Carrier Bearings make maintenance and installation a breeze with a greaseable, self-aligning bearing and a two-piece cast or billet aluminum design. We include a Remote Grease Line with your carrier bearing to give you easy access to your grease fitting without requiring you to remove any plastic.
655123
655122
Not sure, but it does not look like it.
That's a shame, when I fix these things for myself and others we have noticed zero grease many times in the cross needle bearing caps (joint) would be great if some manufacture installed zerks so they could be greased and add to life expectancy.
craigstumph
Discussion Starter · #11 ·
This may help.
1 - 19 of 19 Posts
