I ordered the RZR to RZRS +5 1.5 Front/Rear Long Travel Kit from SuperATV® and fast as fast can be it arrived faster than expected (that's fast for Alaska). Now If you have installed the Kit I'm sure you will agree to the directions being outstanding with the only exception that maybe they needed to add the fact that the powder coating around the insertion point for the Ball joints should (in my case MUST) be grinded/sanded down (top & bottom of the A-arm) to get the snap rings back in place. But that's not where I found my problem. When I installed the tie rod extension I found that at the MOST, all I could get threaded was 3/8" and that was with some toe out with the alignment, if I aligned the wheels up perfectly I was only getting a 1/4" at most. Now this was puzzling and I racked my brain for hours and finally called SuperATV® and to my delight was helped instantly, we talked, I sent some quick pictures from my iphone® and they (SuperATV®) said that they would immediately ship out a new extended set. I was very happy offered to send the others back but they insisted no need! Now that's customer service. So the new ones arrived and problem solved instantly, Perfect alignment (actually had to shorten the new extensions just a little to get the locking bolts to fit to tighten them up good), But that was more them doing a great job in anticipating this "issue".
If you know of a better answer please chime in: I racked my brain the last week and I came up with why I would be short on both sides this crucial 1/4 inch and this is what I came up with...
The Kit is not just the +5 LT. It also has the +1.5" front & 1.5" rear. Now the rear didn't matter but the 1.5 front would. I did some measuring and all that math I learned in school I found that its a small factor of between 1/8" and 1/4" and just wonder if I got adapters for the non 1.5" front kit? another small faction I could find was the possibility (not in my case) that when you drill the new hole in the spindle (increase the size) if you are off by 1/16" when drilling, well then you might as well be off by 1/8" if you do both sides the same. The 3rd Probability is the actual steering rack, now I'm sure some might argue not possible, but?
In the end my consensus is that It was the 1.5" + in the front that did it. extending the wheels just that 1 1/2" shortened the tie rod "grab" length costing me that valuable 1/8" on both sides. In the Pictures you can see the one that came with the kit with all the extra "threading" to the left (I threaded the proper amount on the right side) and the replacement they sent me. I've checked everything over and over for the past week. You only need 1/2"to be good..... anyone....
A big thank you to SuperATV® for superb help and service, The kit is Rock Solid!
