1 - 3 of 3 Posts
So i had a wore out wheel stud so i bought i new one today and picked up a few spares only to realize that even all the way in the hub assembly it is spinning inside. Im guessing the hub assembly is stripped out. How do i fix this problem? Where can i get a whole hub assembly and how much? What about tack welding the back of the wheel stud to the assembly? Thanks
I just wanna ride
If it was mine I would buy a set of hubs from UTV Ink. Click here I know it's more than you want to spend but it will bulletproof when you're done.
You can add wheel spacers, put a bolt and lock nut thur the bad stud and good to go ;-)
1 - 3 of 3 Posts
