Steering Wheel Nut Size????????????????
1 reading
15K views 27 replies 15 participants last post by  dudeonit
Can someone shed some light on this for me. Know one seems to know.
What is the size of the steering wheel nut?
Thanks in advance
May be it is, somewhere around there. By the way the best way I found to remove steering wheel is loosen nut, but keep it on a couple threads. Then while sitting in rzr, adjust the steering wheel low enought to pull on the bottom side of steering wheel with your knees. Then with one of your hands pull on top of steering wheel while with the other hands hit nut with a hammer. It will come off a lot easier than prying it off, trust me!
After much trouble I finally removed the steering wheel. Though it looks like there is a gear left behind. How the hell do I remove it? Ive tried using a gear remover with no avail.
Pleeeeasse help. This is getting nuts. I want to call Polaris and bitch at them.
It is mushroomed a bit but I think I can hack saw a couple threads off and be ok, but I wanted to first remove that steering hub (gear thing).
I have a grant steering wheel with adapter which has the tiny spline configuration which will fit once I remove that hub.... right?
try heating the part that came out of the steering wheel and spray some penitrant on the slines after the flame is gone(penitrant is flamible) and try to get it off with the puller heat will make it swell up dont get to crakzy you dont want the shaft to heat up just the leftover hub...
Wow looks like you ripped that out of your steering wheel. It should look like a tapered shaft.
Tre,
pull the pinch bolt out of the u joint under the column. pull the shaft and go work at your work bench vise.
It looks to me like you need a new steering shaft to go with your steering wheel. You could do the electra steer or a 2:1 steering quickner for racing instead of buyinga new shaft from Polaris
#22 ·
I just did this entire process last week, my wheel was not coming off period. So I cut wheel off with saw zaw, lots of penetrating oil used, put heat on it (enough to burn the oil up) and then had a puller on it(two prong). With a lot of turns to the puller, the sucker exploded off while under heavy pressure. It was a MF'er, biggest challenge to go through my shop in a while.
#23 ·
I have a 09 RZR S.....the nut size is 15/16. I haven't destroyed the stock wheel yet, but tried several of the methods suggested on here (including the rachet straps to the roll cage and smack with a brass drift.) Beat on that thing til I mushroomed the brass real good.....the steering wheel hasn't budged. Also used about a half can of WD40....still nothing. Any further suggestions?
#26 ·
Ahh the steering wheel nut... That mother effer pissed me off... 1st I couldnt get the wheel off, then I ended up beating the crap out of it so bad I damaged the threads..Then I cross threaded that sucker when I went to reinstall it.....
Went down & bought a larger Die & re-threaded it (5/8 Standard If I remember right). Im running a 1" nut now... It was a much needed replacement, now the new wheel comes off easy & I haven't had anymore issues w/ the threads...
Stupid is as Stupid does.. Taking a hammer to it is not wise!
#28 ·
I used a 1.5 " wide ratcheting tie down. Wrapped it around the steering wheel hub and the upper rear roll cage bar. Applied tension and used a poly round bar. rapped it once, voila, off!!!
