I have a 2010 rzr with a 6" lift. After several rides I recently noticed wayyy to much slack/play in my steering. Upon further inspection I discovered the stock rack n pinion seems to be going out (looks to be the bushings? holding the rack are wearing out, allowing the rack to move up and down causing the problem). With my lift and 30" backs theres alot of load on the stock steering. Instead of just replacing with another stock unit I'm wanting to upgrade with an aftermarket assembly that will hold up longer and be able to handle the larger parts. The lift I'm running came with larger tie rods, tie rod ends for the rack and hiem joints- both ends.
So, my question is, would the gear one be better for my application or the smaller unisteer??
I've read threw several posts and opinions vary. Will I actually need to modify a brand new Gear one unit just to install it? Thats alot of cash to spend just to end up whittling it down so it will fit.
Any help is much appreciated
