My daughters 170 starter stalling and not wanting to restart. When it does start is will only stay running for a short period of time. Sometimes it will let you push the gas pedal full throttle, other times it will not and will just stall. When cruising it will then start back firing, loose power and then stall. The run fine for a bit and do it all over again.
CDI or fuel pump?
CDI or fuel pump?
