No. The high clearance trailing arms will hit the ST links, it will also hit the SuperATV links. I went with the SuperATV HD trailing arms. Not the high clearance. Those do work great together with my ST links and sway bar. The SuperATV HD trailing arms add a 1” to the wheel base. Those they do allow for more rear ended clearance. I really like mine.
however if you really need the high clearance trailing arms. Look at the high lifter brand.
Thanks for jumping in @CyborgPirate . Yeah, not sure about ST but the WE links won't fit down into the high clearance trailing arms, but they work great on the HD trailing arms.
