I have a 2021 rzr xp turbo and want to order the overhead audio system does anybody know it it will work with a aluminium roof as well i dont want to lose my roof, also anyone have pictures of one from the top? thanks
It clamps on the stock roll cage. This is how I installed it on my own....foam padding and jacking up with ratchet straps. This pic is with the clamp still loose...when it is tightened it will snug down right on top of the roll cage. Clamps on both sides. Should work...may need a strip of foam on the roll bar forward and rear of the clamp.
It will. I have exactly the setup you are asking about. Aluminum roof and SSV system. I do have some foam to keep it from rattling. It works just fine.
