1 - 4 of 4 Posts
· Registered
I just picked up my new rzr from the dealer earlier and ran into a few problems.
I installed the SSV works overhead system and cannot figure out what the harness with the purple and green wires is for. Antenna? It works with just the wires hooked up to the battery so I am not sure what the harness is for. The fm stations do not pick up at all so I thought it might be for an antenna. Help please.
Also the seat bag that I ordered from SuperATV. As simple as a seat bag should be I cannot figure out how it attatches. It does not have any snaps or anything....?
Thanks for the help.
· Premium Member
The extra harness is for our 2 speaker add on directly from Polaris. If you buy that add-on it simply plus right on. About 10min install start to finish.
The fm largely depends on where you are, what station. If you have a roof. Are you in your garage etc...
Call us tomorrow and well give you a few tips. Way too much to type on the iPhone :)
Trevor
818-991-1778
· Registered
Discussion Starter · #4 ·
Thanks for the help Trevor.
By the way the seat bag was very simple to install. I felt like an idiot after figuring it out. Apparently it wraps over the bar and has storage on both sides instead of just one which made it fit perfect. I had too much stuff to put on the rzr after first getting it and did not focus on one thing at a time. Talk about moving backwards...lol. Thanks for the help guys.
1 - 4 of 4 Posts
