1 - 20 of 47 Posts
· Vendor
SSV Works now offers plug and play powered subwoofers that are electronically tuned for use with the Wetsounds Stealth series sound bars or Polaris RZR 1000 / Turbo optional audio systems.
These SSV Works weatherproof powered subwoofer systems are all inclusive and use the SSV Works digitally tuned onboard 300 watt Class D amplifier and SSV Works Carbon series 10" subwoofer.
Like all SSV Works enclosures and speakers, these are 100% weatherproof and backed by our industry leading Limited Lifetime Warranty.
For more information on these Powered subwoofers, please click the following links.
Glove box subwoofer:
SSV Works - Side by Side Vehicle Specialists
Behind seat subwoofer:
When ordering online, be sure to use the drop down box to pick the part number right for you.
****When using these powered subwoofers with a Wetsounds Stealth series sound bar some adaptors may be required****
SSV Works Inc. the originators of sided by side audio since 2006
818-991-1778
· Registered
If you got this amp, but it was not tuned for the soundboard, how would one go about it. I see the adjustment knob on the amp, but there is a switch with three positions, and I wonder what this is..it has three settings 75, 100, and 150 I think. Any help would be appreciated.
· Vendor
Discussion Starter · #4 ·
Each SSV Works amplifier is electronically tuned using an oscilloscope to ensure the amplifier is matched to the source unit. If you send the amplifier to us we will gladly tune it for you the correct way.
The switch you are referring to with 75,100 and 150 are the crossover setting and have no effect on input sensitivity tuning.
Improper amplifier tuning can cause damage to the amplifier and woofer that would not be covered under warranty. Please contact our customer service department @ 818-991-1778
· Registered
Greg, I have a wet sounds stealth 10 ultra and can't decide on which powered sub to get, my dealer thinks I need the glovebox enclosure with a kicker amp and sub. I like the plug and play part of the Ssv powered sub. If I go kicker in your enclosure can I get the adapter needed to plug the stealth into the amp from you also. Any ideas would be great.
· Vendor
Discussion Starter · #7 ·
I would recommend the plug and play glove box option. These are 100% all inclusive and do not require you to purchase separate components and are really simple to install. If you build your own sub using separate components, it will be much more expensive and require you to mount the amplifier and wire the woofer.
you will need a 3.5mm - RCA adaptor no matter what and unfortunately we do not carry these.
· Registered
Thanks, placed my order today, my local Radio Shack has the adapter. ?
· Registered
I'm interested in your glove box sub for my XP4 but have a few questions:
- is it compatible with the Polaris mtx overhead speakers, how is it connected?
- do I need to add additional batteries for the sub?
- is there a controller for the how loud the bass is?
· Vendor
Discussion Starter · #13 ·
If you order a sub specifically for the Polaris MTX system, yes it is a direct connection.
No additional batteries are needed.
We offer a subwoofer control part # WP-ASLC that will add $24.99
Please let me know if you have any additional questions.
· Registered
Thanks Greg. Can you PM me a quote for a few watt options w/ sub control?
· Vendor
Discussion Starter · #15 ·
My charging system can barely run my fan all day non stop. How am I going to be able to power a sub?
All SSV Works audio solutions are designed for factory charging systems and depending on you other accessories should not to require any charging system upgrades.
If you are having trouble with you factory charging system keeping up with your Fan alone, I would recommend you talk to your dealer immediately
· Registered
Do you have any pics of the behind the seat sub? I saw a couple on website but doesn't show much as far as room it takes up. Also if you get the Kicker upgrade is it direct wire to Polaris MTX overhead radio? Thanks.
· Vendor
Discussion Starter · #17 ·
Please click the following link to the full installation instructions of the enclosure. The powered subwoofers are built with a matched woofer and amplifier and are not available with Kicker woofer upgrades.
http://www.ssvworks.com/ecom/download/WP-RZ3BS10.pdf
This enclosure sits in the engine side of the vehicle and does not take away any usable space in the RZR.
· Registered
Thanks for the info. I just saw the kicker as an option so figured it might work. Thanks again.
1 - 20 of 47 Posts
