Update...
Although SSV recommended a second battery to solve this re-connection problem, I didn't want the additional weight. The real issue is during the reboot SSV loses the bluetooth connection. It eventually reconnects but if the volume is up the re-connection chime is so loud it could make your ears bleed. It really seems as if SSV could fix this with maybe something as simple as a software update that automatically reconnects the bluetooth without the chime and automatically starts the music. May not be that easy.
My fix for now is to connect an Iphone directly to the system. Now when the system reboots it only takes about 5 seconds to begin playing after startup. No ear splitting chime, no pressing play. The only problem with this solution is there is not enough room to use a convertor from 30 pin (the connection in the SSV system) to the current Fire Wire Iphone connection. I had to revive an old Iphone and upload my music to it.
