There is a squeaking noise on my rear wheel passenger side. Noise only happens when utv slows down and weight loaded such as turning left. I read from other post about it maybe the wheel bearing especially when there is wheel movement side to side when jack lifted. I replaced the rear wheel bearing and greased up all the bushing but the same problem exist. Is my problem in the brake area? Any suggestion/advice is appreciated . Thank you ...
