21 - 35 of 35 Posts
Discussion Starter · #22 ·
Think i found yhe problem. The case was half in half out off the engine. I pushed it in and it fired right up . The bolt is missing. Any idea of the cost bolt size?
That was cps bolt came out .now I need bolt size to replace.
Should be a m6x20mm
  • Like
Reactions: Darth RZR
M6 X 1.0 X 20mm
Discussion Starter · #31 ·
Just chasing wires . Happened to look for the sensor with alight .and it looked strange so I got a long screw driver and pushed it in and whammy it fired right up.now I have to find the bolt to hold it in. They built the machine around it.then I can take test run and see if the sputtering after 5 miles goes away.
Good find. I did my pinion nut recently and with diff out I looked at mine but I'll have to keep an eye on that in the future. Good luck man hope that solves it.
21 - 35 of 35 Posts
