1 - 12 of 12 Posts
What are y'all using to protect springs and shocks from rocks on the rear. ordered some assault industries shock gaurds but they don't fit high lifter edition.
Community Smart***
Rear is the only thing on mine getting beat with rocks
You need to order Part Number 5258172
It's number 2 in the Diagram... You will need two of them... You will also have to take apart your back coilover and place this between the seat and spring...
#2 in the diagram is only part of what you need. The actual guard is #5. #2 is the mount for it.
Your other option in shock covers, PRP makes neoprene ones. Ive had them on for about a year, no problems, they are a little tight to install. Or Ive seen guys use a leg off a pair of pants, remove one end of the shock, slip them over and zip tie around the top and bottom.
1 - 12 of 12 Posts
