1 - 2 of 2 Posts
The SBT has been Moab tested! We ran 6 of them in Moab about 3 weeks ago. They held tight no matter where we stopped.
Daryl and Rhonda will be there with with a bunch of SBT ready to install and at a special RotR discount.
Do yourself a HUGE favor, don't hit the Moab trails without one installed (it takes 2 minutes)
Have fun, be safe..... Post pictures.....
Spring Brake Thingy
Discussion Starter #2 (Edited)
NEW - Spring Brake Thingy is LOCKABLE... Check it out...
Fits all RZR. (not the ACE)
Made so that you can LOCK your RZR!
Keeps knuckle heads from running off with your $25,000 RZR for about $80!
Takes 2 minutes to install. Seriously, it will probably take you longer to find the 13mm socket you need than it will to do the complete install.
Spring Brake Thingy, simply works and works simply!
You can stop anywhere, set the brake and no worries about that dreaded CLUNK when you want to go from PARK to DRIVE.
Works really great for hauling your RZR. Tie it down, set the brake, put your transmission in neutral.
Coming soon, Spring Brake Thingy for Wildcat and CanAm!
Order on-line at www.springbrakethingy.com
Then.... GO GET DIRTY!
1 - 2 of 2 Posts
