Speakers
3.5K views 12 replies 6 participants last post by  tazz3069
For those of you who purchased your RZR with door speakers installed, have you noticed that at all 4 connections, is wired backwards. Black/White-White and White to Black/White. I was wondering why my system was sounding like crap.
One under each front seat and the other two were in the rear wheel wel zip tied to the frame
I took 4 pictures. Its kind hard to tell in the pictures. I had to twist the connector 180 degrees so that you see the wires do not match up. Picture 3 and 4 show it the best. Now all 4 of the connectors are the same way. I have already looked and you can not reverse the connector.
I have not change them yet. I will this weekend. I install home theater systems and yes it make a big difference. I looked at the speaker and can not change the connection there. I will need to cut the wire and re-splice it.
yes I did and yes it made a difference .
