The SSV Works A6 Speakers is 100% purpose designed for SXS applications and is backed by our Limited Lifetime Warranty.
•Specs: 6.75” Powersports marine speaker with 25mm Titanium hard dome tweeter, Santoprene surround, UV Stable ASA plastic grille with optional Chroma grille color inserts, 2-pin posi-lock connectors, 4ohm, 60w RMS/120w peak power, just 2-3/16” (5.5 cm)
•Marine speakers are great for boats; however boat speakers don’t get as wet, dirty or muddy as you do in a Side X Side. WP-A6 speakers feature an EPDM duo lock gasket surrounding the speaker to keep the water out and the sound pressure in. EPDM conforms
•SSV Works speakers feature a unique positive lock connector to prevent speaker wire detachment inside the enclosure. No matter how hard you drive, your speakers will keep on rockin’.
•The 25mm Ti- tweeter creates crisp brilliant highs engineered to be heard outdoors, even in a helmet…over the motor…haulin’ down the trails. The grille mounted tweeter allows for peak cone clearance and maximum output while providing a low profile.
4 ohms
https://www.ssvworks.com/product/SSV_Works_Powersports_Speaker
