Drivetrain, main gear case - internals - item #80
Got it thanks
Now that's what I call customer service...Measure that hole for me and I will make you a guide with a 1/4" hole through it. Then gently drill until you get it started. Drill then easy out
GA.Measure that hole for me and I will make you a guide with a 1/4" hole through it. Then gently drill until you get it started. Drill then easy out
I am at work and can’t measure it right now but thank you for the help..... where are you located
GA. I can ship it to you.Measure that hole for me and I will make you a guide with a 1/4" hole through it. Then gently drill until you get it started. Drill then easy out
You are awesome!Measure that hole for me and I will make you a guide with a 1/4" hole through it. Then gently drill until you get it started. Drill then easy out
10-4 the closer the betterI'll mic the hole diameter for you shortly.
Glad I bought a CVT filter from you guys! Good to see stuff like this!Measure that hole for me and I will make you a guide with a 1/4" hole through it. Then gently drill until you get it started. Drill then easy out
