Just installed the heavy load kit, and installed everything as instructed, the only thing that i don't have on it is the high performance belt, which is recommended, I'm running the EPI HD belt. Anyway I got it all together and im hitting the rev limiter right off the bat, i can only hit 40 mph and its reving at 6550. the kit came with 62 gram weights and it called for adding 3 grams to the last hole, do i not have enough weight? would not having the HP belt really make that much of a difference?
Im stumped fellas:rollfinger:
